Fibaro Dimmer 212 S1 and S2 in Rules
Greetings,
I Have a Zipabox and installing the fibaro dimmer 212 for my light control.
I wanted to ask if it is possible in any way to include the S2 switch of the fibaro
dimmer in the rule manager to show up as a control device.
I am trying to use a dimmer to take advantage of the S2 to activate specific scene without
interfering with the S1 native function.
Ι have solved the problem by creating a rule and thus using the controller to perform a specific action when pressing S2 switch.
I searched and found the configuration values of the fibaro Dimmer and then created a rule for the specific actuator using the config value used to address to the S2 switch.
