Deactivate motion sensor based on luminance
Daniel Larsson shared this question 9 years ago
I have associate a motion sensor and a switch and it works fine, but I want to deactivate the motion sensor if the luminance are higher than X lux so the light don´t will go on. Is it possible to make a rule that solve that?
I have Fibaro Motion Sensor and Fibaro Wall plug.
Yes, it can be done. Fibaro motion sensor can be active only at night based on luminance, check the manual on parameter 8 and 9.
However, keep in mind that if you do this and your sensor is part of your Alarm system it will not work during the day.
Also you can do it by rules, it a bit slower but works just fine. Is basically a IF ELSE puzzle inside a WHEN puzzle.
