Please help!
HB shared this question 13 years ago
I have a problem...
Have a Fibaro Door/window Sensor with temperature connected to my ZipaBox
Today I saw that the battery level for it was down to 32% (was only weeks since installed)
When I look in the Events Panel for the device I see that it for some reason CONSTANTLY switches OPEN/CLOSE (see picture)
Ofcourse that is the reason the battery is drained!
But what can I do to stop it???!!!
Can I turn off the door sensor in it... I can live without it for some time.
But I very much need that readings from the temperature sensor!!!!
I have 400km car trip to manualy fix it, so how to stop this battery drain remotly?
What can I do???
I was thinking that the battery should live for a year or two.
Strange! I do have the same sensor wo this problem.
Sometimes i have experienced multipel open states But not
continuously like yours. Did this start now after firmware update?
Have you tried to re-apply the descriptors?
Solved! (for this time)
First tried re-apply... didn't help :-/
Then changed the configuration from NORMAL_CLOSED to NORMAL_OPEN and did a SYNC, then it stoped! :-)
Changed back to NORMAL_CLOSED, and the problem is gone.
(at least not flooding events)
Must have been that sensor that got some (in swedish) "tuppjuck"
I have the new firmware, but this must have been something in the Fibaro sensor, don't think it is Zipatos fault!
I always hate when things gets "tuppjuck"... ;)
