Scene Activation using S2 of mh-P220 dimmer
Vineet Bhojnagarwala shared this question 9 years ago
I've this dimmer:
https://www.zipato.com/product/mini-energy-dimmer-2
and I'm trying to Set S2 to activate scenes, I've set param 19=10, 20=20 & 21=30, to invoke Scene-Ids 10,10 & 30 on S2 one click, double click, and click & hold. But I do not find a way to associate or link the Scene-Ids set on the dimmer to the scenes set on zipato controller (zipatile).
Neigher, can I find any actuator/sensor where the S2 press is recorded and scenes may be invoked with rules. What am I missing ? any guidance will be appreciated.
thanks.
I've raised a support ticket, and I'm trying to wor it out with zipato support, but no success yet.
Have attached two pictures, which zipato says how it should be, check "Zipato wall dimmer", and mine "light dimmer" has only one activate scene attribute. I was suggested to exclude/iunclude which I did multiple times with same results. Anyone with correct or Incorrect attributes may pls chime in.
Zipato team has fixed it server side and now the scenes work.
However, gesture dimming control does not work, working it out with the support.
