Delay for Controller Down Warnings
MaLi shared this question 9 years ago
With the "issue" of Zipatile momentarily loosing connection over WiFi (android issue more so than Zipato if I remember correctly), is there a way to set a delay for this warning ?
It's a bit annoying getting these warnings (usually at least once per day) when I receive the "your controller is up" message before I even receive one about it being down in the first place.
Further more, I don't want these warnings / calls just because I restart one of my controllers.
Ideallly I'd like to see a configurable time-out period to counter this issue.
Sent: Wednesday, August 16, 2017 2:49 PM
To: XXX@gmail.com
Subject: alarm event
Hi X,Read very carefully, this isa very important alarm message.
Your Zipato with serial number XXX reported:
The controller isunreachable
Details:
Message: controller offlinePartition: SystemArmed: HOMETripped: false
Cheers.
Sent: Wednesday, August 16, 2017 2:42 PM
To: xxx@gmail.com
Hi ,Read very carefully, this isa very important alarm message.
The controller is reachableagain
Details:
Message: controller onlinePartition: SystemArmed: HOMETripped: false
Cheers.
Update:
Ups, I just found out, that there is a delay option with the battery / online alarm. I´ll try that out, perhaps my problem is already solved. Perhaps that is what you are looking for:
/D7ELm4yo87jrAAAAAElFTkSuQmCC
Old post:
Very good idea! I use an extra rule just to disarm the battery alarm each night during the period where my router gets a new IP adress. With a configurable delay I could skip that rule
(First scheduler fires at 2:00 and the second at 3:30)
/wiksDBb65xWAAAAAElFTkSuQmCC
And yes, it works even though I don´t have the "Uhrzeit of" (now) tile.
Update:
Old post:
Any update to this ? With 15 calls in October alone this is progressing from a nuisance to being very frustrating.
Dear Zipato,
I don't consider this issue resolved.I'm unable to find a setting that allows me to set a delay for when the "offline" alarm is triggered.
Hello MaLi,
you have to save and sync the controller of youres, afterwards it should be working.
Stefan
Thanks, I did save and refresh but still no options for offline warning delays. (which seems weird that they'd be under the alarm section anyway since some people may not use the alarm function of Zipato)
As an FYI - I do NOT have the backup module, my original request is not related to the backup module.
