Update sensor and actuator endpoints with Room name automatically
Dan OC shared this idea 8 years ago
I would be a great help if when adding a decide, for example a multi Sensor that you are asked to select a room. This room is then added to each endpoint of that multi Sensor.
At the moment I have to manually rename all the endpoints so I know which motion sensor is in what room in the rule creator
