Connect IKEA FLOALT to Zipatile
What I read in the forum is that IKEA product works with Zipatile.
But I can't make it work with IKEA FLOALT.
I tried to factory reset it with power of 6 times. After that I can't connect with the zipatile.If I use IKEAs TRÅDFRI remote I have to keep 5 cm from a certain point of the light to connect. Is it the same whit the Zipatile? In that case, witch part of the zipatile is supposed to be 5cm from the connection point of the FLOALT?
Fredrik,
The reason you have to use Ikea's Remote Control gadget 2cm from the light when adding to their gateway, is that they activate the ZigBee stuff that way.
My bet is that the Floalt LED pamels will work perfectly with Zipatile, but that you would want to first add it to the Ikea gateway, let it update its firmware, THEN start Zipatile->New Device->Zigbee and then immidiately REMOVE the lamp from the Ikea gateway. This causes the lamp to do a proper reset and to search for a new server.
Fredrik,
I tryed to do like you described. It did not work.
The behaviour of the LED-panel seams to the same as turning off and on the power 6 times.
When I connected the remote and the panel to the gateway I learned how to do it with the IKEA gateway. Then I tried to imitate the same prosedure with the zipatile. It did not work.
Any more advice? please.
Uppdate
I read this article and fond out one more thing to try.
https://www.smarthomegeeks.co.uk/how-to/add-ikea-tradfri-philips-hue/
Part 1:6 Last time I did not turn of the IKEA bridge. Now I did the same thing but turned of the bridge after I removed tha LED-panel.
This time I did also try Part 2:1 Turn off an on 6 times.
I did also follow the advice Part 2:2 and touched the LED-panel with the Zipatile.
Result. It don't work.
The firmware of the LED-panel is 1.2.217
Anyone? Any more advice? please.
Uppdate
Fredrik,
IKEA is kind of nice; they allow me to buy a Floalt 60x60, take it home and play with it, and return it later for a full refund. So, i drove over to Ikea (15 minutes drive) this evening and picked up one. Tried, but didn't succeed to connect it to Zipatile. Will try more later this week.
Fredrik,
Device is supported for some time now. Try re-adding it and it should be displayed properly and work.If you are still experiencing problems with it, open up a ticket and we'll inspect it.
