Is it possible to have only one alert per day for an event.
Bruno shared this question 13 years ago
For example i would like to know if it's windly, but not every 10 minutes, just one time per day.
Are you using Rules creator?
yes, for example i want to know days whoes wind is between 40 and 90 km/h. When this is the case, i receive a mail each 10 or 15 minutes.
I want to know if temperature is under 0°C too --> idem
Add some puzzle logic in the rule.
Store the date when you send the email in a variable and check if the stored date is todays date, then skip the send.
Storing a date into variable is good idea but currently comparing date don't work, so I would suggest you to use a rule like this:
UH66FeeRKYiSd61MGPTR
ok thanks !
