imperihome pro
yves shared this question 8 years ago
Hello. Is it possible to install Imperihome Pro on Zipatile? Thank you.
you will need to try and find the apk from somewhere. As Zipatile does not support Playstore, you will need to download the imperihome app from somewhere else and see if you can find a pro update. Not sure if it will work as the pro update relies on playstore.
Yes it works. Download/purchase Imperihome and Imperihome Pro on an Android device in the play store. Then download a program like apk extractor. With the extractor you can generate the apk files for both imperihome and imperihome pro. Finally just copy both apk's to Zipatile and bob's your uncle.
Hey,
but I think imperihome tries to call the playstore and then you get an error message?
no.
Just need to take your 2 APK (imperihome lite and pro)
Ahh. I will try :-)
Super! Thanks, it works.
