imperihome pro
Hello. Is it possible to install Imperihome Pro on Zipatile? Thank you.
you will need to try and find the apk from somewhere. As Zipatile does not support Playstore, you will need to download the imperihome app from somewhere else and see if you can find a pro update. Not sure if it will work as the pro update relies on playstore.
Super! Thanks, it works.
