Zipato security extension module
Hellô i’ve just installed the security extension module. Connected a pb battery 12v
Connected a open door detector but never switch to open or close, I connected two wires to the security module (green tocom and blue to z1)however the detector has 4 wires
(Blé green yellow orange ang greenDid I miss something ?
Thanks for your help
Hi Guys,
You can connect to the security expansion module as in the attachment. The following video will also help you or you can email support@zipato.com.
https://www.youtube.com/watch?v=nnYUzBHEkA0
Best Regards,
Mehmet
Hi Guys,
Best Regards,
Mehmet
Hi Guys,
Best Regards,
Mehmet
Hi Guys,
Best Regards,
Mehmet
I did what is described below however when z1 and com are open , door is in active state and not closed. When z1 and com are connected door is inactive and not open
There seem to be something wrong,
In addition where do I connect tramper cables?
it all depends what kind of detector you are trying to use. Is it NO or NC?
Hello
It is normally open( I declared it in zipabox)
So when not connected door should be seen as closed
And when z1and com are connected door should be seen as opened
Le 13 nov. 2017 à 15:58, Zipato Support Portal <mailer@3plus.hr> a écrit :
Hello
Try to swap it around if this helps.
Sorry maybe I was unclear I declared security module zone 1 as a door sensor normally closed and connected two wire to z1 and com respectively.
When I short z1 and com it says inactive when unconnected is says active
But never says close or open ( don’t you think it should when shorted or unshorted?
Appreciate your help what do you mean with swapping, is it using another sensor ?
I don’t have one available yet
Thanks is there any way to have close/open informations instead of active/inactive
Do I have to create a virtual sensor ?
Ok thanks for your answer
How can I have open/close information instead of active/inactive do I have to create a virtual sensor ?
no, unfortunately this is a flaw of the zipato programming and labelling. I am not sure why a simple sensor that is changed to be a door sensor can not have its status updating to reflect open/close instead of active/inactive, but it just doesn't. It has been this way for years for any sensor that is not officially supported as a door or gate, etc sensor, it just has the status of in/active. Same goes with any other type of sensor, eg motion, water, wind, etc. if you change the devices description from a generic sensor to what it actually is, the status description doesnt change. Sorry.
