Is Zipatile compatible with Sonoff devices? Like shown on the attached photo
David shared this question 8 years ago
Thanks!
DavidSpain
Replies (6)
Hi, Zipatile is not compatible with Sonoff device.
List of supported protocols you can find under https://www.zipato.com/how-it-works/compatibility
4
Not compatible for now? Is there a chance to get it implemented?
i'm going to try the integration via IFTTT. I will use the inching module for opening garage door, for this I just need to send the opening command
3
Hi David,
I'm actually looking into the same thing, trying to integrate Sonoff with Zipato. After some research I think we can do it through MQTT by replacing the software on the sonoff and then publish through Zipato MQTT, however I havent started with that test.
https://www.youtube.com/watch?v=8mz5sCAvDAY
How is your integration going?
I would have liked it.
no integeration, but you can link it via ifttt.
Setup the sonoff via ewlink.
then create new applet in iftt, choose webhooks, receive a http request and give it a name.
then add the an event from ewelink.
When created , go to services in ifttt and search for webhooks.
click on documentation , there you can create the https link. (fill in the name of your applet in events.
And use this link in zipato the turn on (or off) your sonoff device.
attached an example, in the http request you fill in the url from iftt.
works well?!? Can You give us an update?!
I got nearly the same question... but little different >>
Is the Sonoff (rf r3) or Shelby working with the Zipato 433MHz modul?
Sonoff and shelby are 433Mhz devices...
Any experiences?!
Good morning. still no compatibility with sonoff? Kind regards.
