Configuring a Thermostat
I'm searching for a tutorial explaining how to configure a Virtual Thermostat in Zipabox.
There are many parameters but I don't know if my 4 thermostats are correctly configured.
Where can I find this KB Document?
Regards,
William
Hi William,For virtual thermostat - you need to have one heating output and one temperature sensor - those are minimum requirements.
In attached video I will use Zipatile internal temp sensor and relays on Zipatile.
After the virtual thermostat is created, you need to wake up sensor and temp should be visible.
Under Virtual Thermostat you can find video with basic configuration.
If you need anything, let me know.
