paradox and PRT3
i'm trying to connect my Paradox with Zipabox with RS232 module.
I connected the PRT3 to my DGP-848 board, question is, do I need to set up the PRT3?
On the PRT board, the RX LED on Panel bus section blinks all the time, TX only sometimes.
RX and TX LEDS in Serial bus section (manual: printer module is sending/receiving information) are on, what is probably wrong :(
Martin
Hi Martin, did you connect correctly PRT3 with RS232 module RX, TX and ground?- Attached is an example how to do it on DSC and Visnet. Wiring should be same.
hmm, i have RX and TX switched. look here: https://www.pdf-archive.com/2017/06/02/prt3-ei02/preview/page/1/
rest is same.
look at the Figure at page2, LEDS RX&TX on the right side do not flash. Leds in Panel bus flashes.
On page1 in the table are described settings, which should be done. Has anybody any tutorial what to do?
btw, nice picture. should be in Zipato manual or KB.
rest is same.
Hi Martin,
Have a look in here: https://community.zipato.com/topic/paradox-alarm-and-zipatile
In case you find no answer to your question, write back here.
Regarding RXTX they should blink when there is any communitation on the Paradox system. Try activating any sensor of the alarm. Then they should blink. If not, check the wiring.
For Paradox config, my recommendation is you use "Babyware" soft from Paradox itself. But I believe there are other ways.
Hi Martin,
hey, thank you, the answer is in this post from you: https://community.zipato.com/topic/paradox-alarm-and-zipatile#comment-33539
i have to make that settings on PRT3.
one more question, were you able to connect PRT3 to computer via USB and then use hyperterminal?
Martin, I am curious about your problem and would like to examine it as close as I can remotely, so I was wondering if you are available for skype chat on Sunday?
Zeljko
Zeljko
guys, please be so kind and point me in the right direction.
I am stuck in the same point, on Starting device inclusion process...
My box is ZipaBox2 with 1.3.65 firmware.
My cable is 1m long, is shielded and have magnets on it, I tested it and works flawless in any other setup. (see picture)
I tested the PRT3 with Putty (and the same cable) and I get correct status and it replies correctly on commands (Zone status, Zone labet etc).
Also I enabled only one zone (see picture) so I can trigger it easly (is a magnetic sensor).
The area is named "A1" and all zones i renamed them to start with the area name. Ex. my zone is "A1 LIV-MAG"
However I am unable to get past the "Starting device inclusion process...".
Any help is greatly appreciated.
Thank you.
Best regards,Vlad
Thank you.
Best regards,Vlad
Hi Vlad,
I would like to investigate your issue of you send me your Zipabox serial number at zcerovski@3plus.he
Zeljko
Hi Vlad,
Zeljko
Hello everybody,
first of all a big thanks to Zeljko, he solved my problem very fast, so now everything is working.
I saw some posts that nobody confirmed the Paradox is working on USB, so I CAN CONFIRM IT IS WORKING. For everyone that is still trying or have questions about this, I will post a couple of tips that helped me make it work.
- First of all, you need a PRT3 for your Paradox EVOs. In case some wonders, all the EVOs are OK, I have an EVOHD and it is working fine. Also it works on the CBUS in the same time with other cards. For example I have on the same bus an IP150, and HD77 and the PRT3.
- When you set your PRT3 (I recommend BabyWare since is very easy) you only need to set Serial port enabled, ON:Home Automation, Baud rate setting to 9600 and Home Automation on Ascii Protocol. You can ignore everything else. Almost all of the other options are for reporting only, when you set the Home Automation, everything is done by specific queries, so nothing else matters. For example, Areas ans Zones, you can set them whatever, but on discovery will find all of them anyway.
- Another thing I didn't tested but others said is a must, is to set the name of the Area and the name of the Zones. Do not leave them with their default name.
- The USB cable should be as short as possible and a good quality one (shielded).
- If you get stuck on Starting device inclusion process, then ask for help here or open a ticket, it seems it is something that only devs can fix. After that the timer starts and after a couple of seconds it finds the alarm and a screen pops asking you to trigger every zone. After that you are all set.
- VERY IMPORTANT You need to go to Users and change the security pin to the master code on your alarm. The default one is 0000. Also the set part of the alarm (arm, disarm, stay) are in the Virtual network, where you should see the name of your partition (area). There you should go and check the QUICK ARM. Otherwise you cannot trigger the actions by rules.
- If you don't know already, to arm/disarm/stay by Google Assistant you need to Add new device, Virtual devices, Virtual sensor. Make 3 of them for every action you want (arm, disarm,stay). Then go where they are installed (Virtual network) and open them until you get to STATE, then click the cogwheel and copy the URL. Then go to the IFTTT, set the Google Assistant on IF, and WebHooks on THEN. On URL paste when you copied previously and don't forget to add the 1 after value=. On Method is POST and on Content Type is text/plain. On the ZipaBox rules side you put a WHEN with a sensor filled with your virtual sensor (Arm for example) and the condition is ACTIVE. Then you put an Action with your partition inside with the action ARMAWAY, for example, then put a WAIT 1 second, then a SET with your virtual sensor inside and set INACTIVE to false.
- This is ALL. The system is very sensible so you can brick it on every step you do, just reboot it and refresh the webpage. I did at least 20 reboots until I got it to work, but now it works.
Good luck!
Hello everybody,
Good luck!
Hello!, I have my Zipabox 1 working with paradox since more than two years ago in a big system (thanks to Zeljko!) I am wondering if the system will work once I migrate to V3 with a Zipabox 2. Can anyone comment?
