Interface iPad/iPhone apps
I like what you have going on with Zipabox :-) Haven't used the system very long, but I have a few ideas you should work on with the apps (iphone and ipad). Basically you have to click around to much to reach whatever you wan't to do. Minimize the amount of clicks!Here's a few ideas:- In 'Rooms' --> there should be an icon for each room you have setup that always shows regardless if you are in the main menu or in a room. Now you have to click yourself back and forth all the time you change rooms. Not very smooth.- There should be quick buttons to the main menu choices all the time.- When using the app you shouldn't have to login all the time. Make a setting in 'setup' where you can set the login time. Minutes, hours and days. And have a special login for security instead (or make that a choice of setting in 'Setup' as well). There should also be a setting were you can chose to which screen menu opens when you start the app for reducing clicks.- Lights & power --> the dimmer adjustment lever must be much longer on the ipad. At least double the length, but I should say even longer than that. It's too difficult to adjust to the right level with the short lever now.On iphone it could be a bit longer as well if you move up the percentage notification up to the same text line as the name. That way the adjustment lever can cover all the way to the end of the screen.- Lights & power --> you should be able to turn on/off dimmer lights when pushing the symbol next to the lever. That also goes for the switches.- When pushing 'Scenes' --> app crashes on both platforms (latest iOS)Aril
Thank you for the observations. We will consider all of ideas...
As for the app crash, can you contact support@zipato.com, so we can check out what is going on...
Before that, please try to add more than one scene in your system and than try again.
Ok, problem solved. When I added more scenes the app ceased to crash.
