Fibaro universal binary sensor
pm03 shared this problem 12 years ago
Not a Problem
Several questions regarding the Fibaro universal :
1) On the control center, it shows "binary sensor 1" and "binary sensor 2" in the Sensors section, nothing else. How can I control the 2 potential-free outputs?
2) On my Ipad it shows :
- Binary sensor 2 : -
- Binary sensor 1 : -
- Binary sensor 2 : open
- Binary sensor 1 : open
while on the web control center it shows :
- Binary sensor 1 : sensor off
Why do the sensors show twice on the ipad (same on the iphone)? Why are the states different on the web control center and ipad?
Has anyone used this device with a zipabox?
Thanks !
PS : in the device manager I can see :
Fibaro universal sensor FGBS321 v2.1
- Binary Sensor 1
- Binary Sensor 2
- Input 1
- Input 2
and parameters for input 1 and input 2 :
- normal open / normal close / monostable / bistable, temp readings interval (20), temp report interval (200), temp report on value change (0)
1- output is not usable from any box, it dépend directly from input. Exemple, when input 1 become to close state, output 1 change
2- same for me multiple sensor visible ... You are not the only one seemsto be a bug ...
Thanks for your reply.
One of my goals was to control 24V irrigation valves, so I guess the best way is to buy Fibaro switches (for instance FGS211)?
Sure ... There is no potential in output 1&2 it free protential that normaly meens it´s like simple contactor on/off
