Danfoss Heating Thermostat
Hi Guys
i have a Problem with a virtuel Themostat.
I configert one with an external Themostat (Fibaro eye) and an Danfoss Thermostat.
It looks well but the virtuel Themostat sends the wave configuration to the the Danfoss Device.
Set Thempetartur is 23° Roomtemperatur is 16°. The Wave Themperatur is set to 23° and the Room Temepeartur goes up. But not to 23°. The Wave Temepeartur is now 23° and around the Danvoss Device it is 23° but not in the room.
For waht a have to use an externer Temp Meter ?
Is there a possibility to set the Danvoss to max Temp until the room Temo is reached ?
In my case it does not work as it shoud.
regards
Chris
Hello Christopher,
you will have to use the temperature offset feature so you can adjust the thermostat more precisely.
Stefan
Hello Christopher,
Stefan
Hello Christopher,
Stefan
Hello Christopher,
Stefan
Stefan,
what temperature offset feature do you mean? Where can it be found on the virtual thermostat? Do you mean the setting for histersis?
Thank you for the clarification.
Beat
Stefan,
Beat
Hi Stefan
is the Offset Feature only in Themostat pro avalable ?
in my Themostat there is no Offset Feature.
Chris
Hi Stefan
Chris
Hi Stefan
please explain us were we can find the Offset Function.
Chris
Hi Stefan
Chris
you can find it on the UI>module manager>IP>internal>
Hi Roberto
thanks for the info. In my box i can´t find under IP>internal. But there is another Folder named internal. But it´s emty.
Do you have the pro Licens ?
Hi Roberto
Hi Christoph,
I had the same problem with one of my Zipatiles, I have a "normal" licence so no pro.
I had to raise a ticket to Zipato to solve this problem.
Zipato did solve the problem, after the reset it was working as it should be and you can make the adjustments.
Regards,
Roberto
Hi Christoph,
Regards,
Roberto
Hi Roberto
i createt a new virtuel Thermostat. Then the box was rebootet. But there is now internel Folder under IP.
Firmware 1.2.29 is running.
Are Zipabox and Zipatile in some cases different ?
Where is the mistake ?
Hi Roberto
Hi Christoph,
as far as I know there should be no difference between the ZipaBox and ZipaTile in programmimg and possibilities.
the answer I got from Zipato is " Hello Roberto, we've solved the issue of yours, if you check the 'show as device' on the thermostat endpoint, the app is crashing. We will limit these options on the new Web UI which is going to be released soon. Best regards,
Stefan
Hi Christoph,
Stefan
I have LOTS of virtual thermostats and a PRO licence, and have nothing listed under internal for offsets.
I did raise a ticket a couple of months ago raising the fact there needs to be an offset between the external temp sensor and the radiator valve. I was told that the offset feature was on the old style UI but was removed and no longer does anything..they said for the use case I had described they would consider adding it back in at some point so am I totally confused by the answer above.
Hi Paul,
my question was about the internal temp sensor in the tile, but I guess it should not make a difference if its the internal or external temp sensor.
take a look at the attached files how it looks in my UI.
as you can see its the software version 1.2.33
regrds,
Roberto
Hi Paul,
regrds,
Roberto
I think those settings must be unique to the zipatile as there is nothing like that on the zipabox
this could well be, due to the fact that the Tile has an internal temp. measurement
Hi Paul Hi Roberto
thanks for the Information.
Ideed that is the Problem. But i need an Offset fo each themostat. Not General.
Roberto can you configure each Themostat ?
Chris
Hi Paul Hi Roberto
Chris
Stefan
can you exlain were we can find the Offset Parameter.
regards
Chris
Stefan
regards
Chris
