How to differentiate sensors in rule creator
Søren Storm shared this question 8 years ago
I´m working on a rule, that should shut down my danfoss thermostats, when a nearby window is opened, and bring the thermostat back to normal when the nearby window is closed again.
I have named my sensors and thermostats, but they show up with generic names in the rules creator.
I found a topic, where a solution was to name the sensor on the second level as well. I tried this on 5 of them, without any luck.
I have a lot of window sensors, 16, and about 10 thermostats. So it´s a pain trying to figure out which is which.
Attached pictures of the window sensors. Same problem apply on the thermostats.
I hope someone knows what I´m doing wrong.
Best regards and thank you
Søren!
Soren,
if you click in device manager on a sensor it should open more detailed. You might have to change the name of a sub member with the little mark on the right side...see attachment.
Hope this helps?
thanks
Beat
Soren,
Hope this helps?
thanks
Beat
I actually already did change the name of the submember. And for some reason it is all right and good now. Maybe it needed some time to change it. I dont know. But thank you for your answer Beat! :-)
Soren,
If you change the name of a device you have to do an "Update" (see Screenshot) on the device list! After that the devices in the rule creator will be updated too!
All these little tricks...
Beat
What I wouldn't do for a single update/refresh/sync button. :-D Yikes. Thanks for the tip.
