Anybody had a SIP Server just dissappear form a Zipatile?
Adrian Van Der Heijden shared this problem 8 years ago
After having a SIP server set up on a cluster with a 2N intercom, all has been working for weeks. Now client just called and says Ziatiles are not ringing, so I check online in the Control Centre, and the SIP server is just gone!!!!
How does a SIP server just delete itself?
Anybody ever had this issue before?
No but i dont even dare trying SIP. For me the doorbird user login details disappear for no reason. Definitely zipato should fix it
Yes Adrian, my client is having this issue. It just wont connect again. We have to go to site again and try and fix it. The first and last time we will be using Zipato SIP.
Attila, I now use the latest Doorbird app as it has local connection mode only option. I remove the Doorbird app from Zipatile, and use apk extractor to get the latest Doobird app version from my phone, then install it on the Zipatile.
I still need to subscribe to the Doorbird notification service for the BellPress, as I need it to ring the Zipatile, or use a Doorbird Chime which is better.
