Leave cluster?
Arski shared this question 8 years ago
Hello, how do I delete a cluster and/or remove my 2 Zipatiles from a cluster?
I'll answer my own question - all is done via the api.
It is also available under the settings menu, you just need to untick the controller you want to remove from the cluster, sync and then the controller will be available in the Controllers selection tab again.
/AYKJvWtU+4VRAAAAAElFTkSuQmCC
i did this but both my zipatiles now say setup not complete. And I can't do anything with them my zipabox works fine./D0XSKrJPVoHrAAAAAElFTkSuQmCCAA==
havent seen that before. Do you have just the 2 zipatiles in a cluster with a zipabox?
Which controller has your devices connected to it?
Is your Zipabox still in the cluster?
Have you rebooted your Zipatiles?
I encountered the exact same problem. I had to push configured=true via the API to make bring the Zipatile back to life.
zipato fixt it. on the zipatile there was a red bar which said contact zipato.
And standalone the HTTP request, virtual devices and rules work again on my zipatiles and box.
in cluster nothing workt anymore
