Everspring HSP02 no motion
Alberto Sagredo shared this problem 13 years ago
Not a Problem
Yesterday i was testing Everspring HSP02 Motion and Lux Sensor. It seems do not work with Zipato . No motion is detected
I had the same problem with an Everspring SP814.
But if it is quite useless please explain how to use the smartness of the system to work with light intensity.
I intend my HA to be based on luxlevel and movement (untill I can find an affordanle presence/heat sensor instead a motion sensor).
Regards,
DK
Marko Kosanovic wrote:
It would be the best to have light intensity meter like http://www.zipato.com/default.aspx?id=24&pid=72&page=1&grupe=0,3_9,0 or http://www.zipato.com/default.aspx?id=24&pid=23&page=1&grupe=0,3_10,0 that measures accurate light level and then you can create very smart rules with our puzzles in rules creator.
I misunderstood your answer in the first reply, I thought I could make the device like SP814 smarter through zipabox by creating the correct rule.
I won't buy them anymore ;-)
