How to avoid "synchronizing..." panel
I'm facing this issue all the time, sometimes it just show up and disappear and sometimes it keeps "spinning" for days, until i reboot the Tile. Is there any solution how to prevent this?
regards
Jozef
IMG_20180116_14...
getting the same issues. Even logging into the control center sometimes doesn't work, and I need to refresh page. Syncing at the moment almost never works with my Zipabox.
The web control center has been getting worse and worse to login for me, the slow loading, page doesn't always load properly, adding a device most of the time just times out, sync either fails or just continues to sync. Even tried a reboot from the control panel and this fails to reboot the controller, I have to do it manually.
Honestly I dont know WTF is going on with Zipato. I was told months ago that the whole backend was being redeveloped to make it more responsive and managable, but besides the latest SIP update which is good, nothing else has improved.
Ok, i had to open a ticket. I'm curious about what the problem was.
So i have created separate wifi network for tile only(ordered eth adapter also), and problems disappeared, or they are occasional. It looks like, stability of network connection is absolutely crucial for zipato communication protocols.
