Add another user to control alarm
thomasfr shared this problem 13 years ago
Hello
I'd like to allow another user to control alarm with the mobile app.
I created a new user in general settings and checked the alarm control.
When I click on the key next to the user name in the users settings (general settings) it says: add user to security partition first
In security partition there is a "user" setting but no way to add another user.
Then if I log with id/passw I created for the new user, it says user not found or wrong password...
How can I add this 2nd user access please?
Replies (18)
After logging out/in I can see the accounts, however, I can not delete them. Also, sporadically I get an error stating that partition does not exist while trying to save user changes in the security widget. I think it's not critical, but confusing a bit...
One thing I can not figure out is how to change the pin for the new user. I get prompted for my pin and new user pin/confirmation but this does not work. I also tried entering 0000 as "my pin" but no luck. Is there any "special" procedure for that?
this is a known bug. It is fixed already, and it will be published with the new firmware upgrade tomorrow.
Hi Sebastien,
When will you publish the new firmware? You announced it last week and the bug is not yet fixed for us.
Thks.
I have reported the same issue (mine is regarding other users' PIN modification). I was answered by support that is has been fixed but we need to wait for fix deployment. I hope it will be part of the next firmware. Sebastien mention in another thread that we could expect it to be issued this week ... keep our fingers crossed
Ahhhh ok, my problem is the same, with other users I can not change the PIN ...
I have also reported the same issue in this thread : http://community.zipato.com/responses/cant-change-security-pin-for-a-new-user . Sebastien announced a new firware to fix it two weeks ago. Unfortunatly no deployment :-(
This problem continues with the new update, we do?
Well I finally accessed the dashboard with 2nd user credentials, but I allows to control everything. My wish is to only grant access to alarm.
Btw what is the default PIN for new user?
Cannot find it.
Thanks in advance
Milan Gulis wrote:
Hello
For now 2nd user has the same right's as main user, except some setting, like "Zipabox settings" and ability to add additional users. We will consider ability to add additional restriction for future implementation.
2nd user doesn't have default PIN code. It can have only PIN code that you set for that particular user.
To set PIN code for 2nd user, log in to your main account. Go to "General settings" and click on "Users" tab. There you can change and set PIN code for any additional Zipabox user. Just click on "key" icon next to user.
Milan, I still have the same problems:
1) I'm NOT able to delete an user; it says "deleted" but it stay in the list
2) Anyway I'm not able to login with the credential of another created user; it returns always "bad username / password"
3) if I click on the key in order to change the pin of a selected user, it ask me for the current PIN and 0000 is rejected.....
After
when I clicked on the Key in order to modify a PIN for a selected user,
it asks me to "add user in the security partition first".....
In other words, all remained at the beginning..... and it is still to solve.....
Any suggestion?
Cannot find it.
Thanks in advance
How did you do? I'm still not able to do that
I am still having the same problem... i can not add another user so he can control the house as well! It says that the owner does not have a ROLE 2?!?!?! What should i do?
same here, seems the firmware is buggy......I am struggling trying to add a second user since this morning.... LOL
Same problem : what is the default PIN for new user?
I can add my second user, works fine! Adding two more works but, I cant save the change for alarm
the system says: securityPartition.notFound.
jag har samma problem. hoppas man kan få nått svar här vad det är som går snett. inge vidare support här tycker jag
same problem:
1st User (Partition Owner)
-works well (Code and Key-Fob)
2nd User (Code and Key-Fob)
- when changing the rights in old app and saving -> securityPartition.notFound
- when trying to arm / disarm - it seems from the Log that the mapping to the User did not work -> ${user.name} is shown instead of Username
- but when trying to "relearn" the Key-Fob in the slot of the Keypad where the User is assigned - The Log states an Alarm forDisarm / Arm but with the correct Username
i have the same problem as the 2 previous writers . we would be grateful if you can help / answer here.
Hi, I found a solution. It had something with user rights. Click the username in the alarm panel where you add users. Then a popup window appears where you can change the user rights. Check the arm and disarm rights and it worked for me.
Thanks Kristian!
