Aeon Multisensor - Reporting wrong negative temprature.
I have a Aoen Multisensor that I have mounted outside the house. It works fine and all the sensors reported right values until it yesterday got below 0 C outside. It only reports 6553,xx (xx changing value)
I don't know if it's the sensor or the Zipato box that's got the wrong values?
Have the very same problem, probably Zipabox interprets temperature as 16bit unsigned when it should be 16bit signed or something similar..
we have also noticed this problem and we are currently looking into it. Thank you for the feedback.
Hrvoje
Hrvoje
Yes obiusly à Signed/unsigned error, but should be à fast and easy fix as zipato puts in à comma before displaying the Numbers.
À question to zipato, how can IT be so that your interface and HomePage report this sensor as compliant, but obiusly you havent testet it...?
I have the same problems, our demosystem and two of our customers systems show around +6500 degrees celcius when its minus outside. :)
I was very impressed with the sensors ability to withstain such extreme temperatures without catching fire. ;-)
Kind regards,
Niklas R.
Kind regards,
Niklas R.
Any solution yet?
Any solution yet?
Nope, I don't know if they need to do a firmware upgrade to make it work? I still have snow at very high temps.
Hello everyone,
this issue was resolved and a fix will be released with the new firmware upgrade in the next few days.
Hrvoje
Hello everyone,
Hrvoje
Hi, thanks for the information and looking forward to the fix since I have the same issue (around +6500 degrees celcius when its minus outside).
Best regards
Christian
Best regards
Christian
Has the fix been released? I am still seeing this problem.
Yes, it was included in the new firmware. Please upgrade your Box.
Hrvoje
Hrvoje
Thanks, after the upgrade it works perfect!
Thanks, it works perfect for me too after the upgrade.
-2,7 outside..... It works
hello i have wrong value in my aeon multicensor,
i read +5° upside real temperature in the dashboard...
