Aeon Smart Energy Switch in rule creator
DaBoss shared this problem 12 years ago
Hi guys,
I've got au Aeon Smart Energy Switch module . . . all work well but it's seems there is not possibility to have status (on/off) of this module in the rule creator.
Is it normally ?
Replies (5)
Do you have any attributes to select when you put on/off endpoint in Sensor puzzle?
Nenad,
I can add my "actuator" on a sensor puzzle . . . then i can make condition on the consumation . . . like
if consumation >1Kw then
But what i want to do is :
if module is on then
I have the same problem with an other Aeon switch. No attributes in the rule creator.
I want to do the same thing if on then ...
DaBoss, now you should be able to use your module on/off state for programing rules.
@soccer skills world cup
I'm having the same issue with my Aeon Smart Energy Switch!
