Aeotec door/window sensor 7
Lars shared this idea 6 years ago
I can't get the TILT sensor working? does anyone have a tip ...
reply from aeotec
Hi Larsoudenijhuis,
Ticket:
The Tilt Sensor is connected to the Magnet sensor, unfortunately the tilt sensor status will only change if the sensor has been tilted and moved away from the magnet at the same time.
The Tilt Sensor will go into a close status if the magnet sensor is in a closed state.
have you already written your essay? You should probably try a grammar checker to be sure that your text is free of any errors.
module added since few days :
https://www.zipato.com/how-it-works/supported-devices?modelId=1657&manufacturers=aeotec&search= ZWA008
Thxs zipato team for your great job !
