Alarm in health care function
Hello
I use alarm with health care function to detect non-activity in house and to pass house in mode no-body at home automaticly (limate in mode away, blinding closed...).
I see that the limite for detection is 999mm => 16h only
Can this timer grow up to 9999mn? or a least more than 48h?
i think it's easy to change that and can make simplier of non detection.
Thanks.
nicolas
the limitation is 999 min which is sufficient for its intended use. The limitation was set deliberately to minimize the chance of errors. The health care mode wasn't designed for switching between Home/Away and leaving your house unprotected for 48 hours would be very unsafe. You should try a different approach in Rules creator.
Hrvoje
Hrvoje
OK thank for this response.
I will make some rules to do that.
Thanks for this post)
The purpose of bed alarms, which are alarms installed onto hospital beds, is to reduce hospital falls. In order for a nurse to assist the patient in walking without falling, these alarms will sound when they attempt to get out of bed. space warzone
