alarm restarts the zipatile
importhomesas shared this problem 8 years ago
Hola
Tengo un problema con este zipatile que cuando se activa la alarma, el zipatile se reinicia.
enlace de video adjunto.
someone else has had this problem
https://drive.google.com/file/d/1B6rHjZIgr2APiK1oSAPbiV8IOXWq764U/view?usp=sharing
Replies (5)
no sorry, just tested a couple of Zipatiles here and they work fine. I would have said its a battery issue, but the fact that it reboots straight away suggests that it is not. How is it powered? Try using a higher Amp PSU, maybe the siren is draining to much power from it.
thanks adrian for your answer
the zipatile works well with the original power adapter I will try another adapter but if it is very strange that happens with the alarm system anyway I opened a zipato ticket hopefully it is not anything serious.
I have the other problem, where the panel shows the keypad to disarm the system even if it was already disarmed by a remote or by mobile. Im unsure why this is a problem.
hello attila
I also have the same problem with another zipatile. I have to restart it to be able to return to normal.
zipato support has not given me an answer yet.
Anche io ho lo stesso problema ma ultimamente faccio fatica a farlo ripartire...
