alarme don't work
mcfly shared this problem 13 years ago
since two days the alarm does not work anymore, I can see my two areas: garage and living room, and when I enter my pin code, I did the proposal: edit settings to create alarm, I heard selected from panic and ca told me to create a partition when I already have 2 ?!
Double what?
it worked until now for 2 weeks and I had not made any changes
Now I do not have all the partitions! must all I start?
Milan Gulis wrote:
Hello
Please check your alarm again, as it seams like you had a duplicate entry for the same alarm, which caused you this issue. We removed duplicate which will resolve your issue.
If problem persists please contact us on support@zipato.com with your Zipabox username/password and security PIN code as well.
Milan Gulis wrote:
Hello
Double what?
i have the same issue. I got 2 partition but after entered the pin code i see just the edit button that open the popup for silent/panic option. I cannot arm anymore my partitions.
Everything worked fine for more than 1 month, then this issue.
Could you help me?
thank you
Mat
