Android App crash all the time...
HeroS - www.domotica-blog.nl shared this problem 12 years ago
When i start the app everthing is fine but when i go to the lights/power section it crashes.
I tried 2 phones...same problem.
The problem is related to the IR repeater and RGBW controller which are still not supported with the Android app.
We are working to find a solution until publishing the new version of the Android app.
Replies (15)
Hi Sebastian,
More users got these problems:
http://community.zipato.com/responses/application-android
Username and password are on the way.
hello, your problem is it resolved?
Nope, support is working on it.
Do you have the Fibaro RGBW device?
no. I have not changed anything in my modules and it worked yesterday
It's working half now. The lights & power opens now but when i scroll it hangs again.
Zipato is there any news?
Also i can't login to the support portal with my login/password from the zipabox.
il n'y a pas d' autre personnes qui ont le problème ? there are no other people who have the problem?
I got this respons:
Android app. There were some fix made on server side which
solved an issue only partial as you are now able to enter Light&Power but
app will still crash after 5 sec.
I can only say that we working on it and hopefully fix will be done i few days.
I also have a work around >> just use rooms :)
ok, thank you !
Since the new Android app is not ready for publishing yet, and the current one has a problem with the newly added support for RGBW and IR devices, try to use this one in the meanwhile:
http://files.zipato.com/Zipato_rc1.60.apk
Great work Sebastian!
ok, thank you !it works!
2Sebastian Popovic
Does this or new version fix issue with arming Zipato security? It is really frustrating to lose control of it
