aucune connexion distante.
Thibault Wittemberg shared this problem 12 years ago
Bonjour, je rencontre de gros soucis de connexion a mes applications Zipabox. Avec l'application Android b je n'y arrive qu'en local, en distant rien. Testé aussi avec l'application Impérihome. J'arrive même pas a avoir accès au site my.zipato.com. bien-sûr je suis bien connecté au web !!!
Est ce possible que mon IP (qui est fixe puisque je suis chez Free) petit avoir été blacklistée ?
Hello, I encounter big problems connecting to my Zipabox applications. With the Android application I can connect in local mode, but not in remote. Also tested with Impérihome application. I can not even have access to the site my.zipato.com. of course I am connected to the web!
Is it possible that my IP address (which is fixed since I'm at Free) have been blacklisted ?
Replies (8)
Is the light on the zipabox Green?
Yes. In fact I think the zipabox works well ... The rules based on calendar work well. I can connect to the Android App when my phone is not connected to my private wifi network.
I really think my IP address is blacklisted.
How can i ask zipato support to accept my IP again ?
Again, my IP is fixed.
OK it works again ... Seems my IP is whitelisted again !
Why do you think your ip was blacklisted?
Because i couldn't connect to the zipato cloud from my home network (only from a smartphone or from work ... Differents IP).
Strange...maybe Zipato team can tell you more about this, maybe it blacklisted for a certain period if you tried to connect too many times (using the android app)...or simply a bug?
It seems to be working again
Tant mieux! ;)
