Bindings (Associations) can't be deleted
w.korsten shared this problem 13 years ago
It is possible to associate a switch to a sensor but the binding can not be removed.
This is fixed. Bindings can be deleted now.
Replies (5)
The only way to remove this binding is to delete the device...
I am still having this same problem.
I associated a Everspring HSP02 motion detector with a TKB On/Off socket.
I have now removed the bindings but the On/Off socket still turns on when motion is detected.
How do I remove the binding without deleting the one of the devices?
I've the same problem. Binding can't be deleted.
I tried with an Everspring HSP02 motion detector and an Everspring SM103 door sensor.My current Firmware is Version 0.9.961
Do you think fixe this problem soon?
This is not fixed for my Aeon multisensor, once a binding is set it can be changed to another device but it is not possible to remove all bindings. The only way is to reset the device.
