Can not use FGMS-001 temperature sensor in the Climate Module ?
olivier34 shared this problem 10 years ago
Hello, I have a Fibaro FGMS-001 module and would like to use its temperature sensor in a "thermostat" in the climate module.
When I select this device in the "Devices / Thermometers", than the temperature shown in the climate module is 0.0.
Note that there is a correct temperature displayed in the "Meters" module.
Sounds like we can not use the FGMS-001 as a temperature sensor in the climate module ?
Please confirm.
Oldest
  • Oldest
  • Newest
Hello Ivan, thanks for your prompt answer.
And I confirm that it got finally automatically updated, it took a while... (basically a couple of hours) but the temperature got updated with the right value.
issue solved, thanks.
