Cannot select a siren or squawk in the Alarm configuration panel
roel00 shared this problem 11 years ago
In the alarm configuration panel it should be possible to select a light as a Siren or Squawk. In the new dashboard web app, this is not possible; when clicking on the Siren or Squawk dropdown menus, nothing is available to select.
The old dashboard allows you to select a light as Siren or Squawk, but when the alarm is armed or tripped, nothing happens.
79d37bedb117336d04aaf9dfdf3c292d
If you have some devices applicable (like sirens, on/off switches) you are still able to add them as a squawk or siren. If some devices are missing or not applicable you can still create virtual switch and manage those devices with it.
Thanks Antonio. I previously only had dimmers, but no binary switches. Now that I've installed those, I can select sirens and squawks. I will try your suggestion of a virtual device too.
