Can't login to support.zipato.com
Ivica Dimitrijev shared this problem 11 years ago
I have problem logging to support.zipato.com
I get the message: Invalid Username or Password
Tried to reset it through lost password form, but still no luck!
Replies (13)
Hello Ivica,
I will look into this just give me a moment
Hrvoje
Please try again using your old password and let me know if you were successful
Hrvoje
Same problem again @Hrvoje:
Btw the Knowledge Base is starting to look pretty good.
Your username/password are the same as on my.zipato.com since those accounts are linked. I have tested this and it should work without problems.
Hrvoje
No. It doesn't work.
I have sent your new password to your email address
It is the same for my.zipato.com and support.zipato.com I have tested it and it works.
Hrvoje
Now it works. Thanks.
Is anyone else having this issue right now? I cannot login to zipato support but I can login to webcontrol center.
It has to be a server issue, my cluster controller is offline on web control center...
Same for me
Same for me
yup same here.
Same for me.
Try again now, its working.
Cheers,
V
As always, thanks a lot for your help.
