Chacon CH54754 motor controller not supported....
Hi!
The question is simple. When the CH54754 module will be compatible?
Thank you and sorry for my English...
We already support this device, but under a different name. In our "Add new device wizard" this device is called "Chacon EJLR-1000 roller shutter".
Thank you for your answer.
When I sync my ch54754 like a EJLR-1000, the window "Synchronization in progress" never stops... (Even if I wait 10 minutes...). So I closed the window.
After that, when I select 0%, the shutter down but then this is impossible to put it up.It stays down. (3V AC on up.)
(Receiver Installation (AC) with AC motor). Same result on 2 devices ch54754 I just bought. I think the device is not fully compatible, no? I need to do a test with the chacon remote to prove it..
Confirmed. The ch54754 is fully usable with the chacon remote control but with the zipabox, only the down function works. "Up" doesn't work....
I leave a message in "problem" section.
I'll have a problem with the old internet version no problem to add the 54754 but with the new internet version it's impossible.
And the Old internet version not available now?????
Can you help me??
Can you help me??
Have you tried to upgrade to the latest beta firmware release?
No i'll not install it.
I'll test and make feedback.
But the old internet interface was better for install chacon.
Unfortunately, you must have firmware later than .8e for this to work properly.
i've just update it and my last beta is 8q.
That should be fine. Try to synchronize, put the shutter in the inclusion mode and start inclusion.
Ok thanks for your help i'll test with the beta and it's work fine.
Thanks a lot.
Thanks a lot.
