Change order of device
Emmanuel Papageorgiou shared this question 9 years ago
Hello
I want to ask if the is a way that i can change the order of the devices in browser.
for example my climate button is the last one and i always have to scroll down to find it.
what i wanted is the light, climate, on off switch to be on the top of the bar because these are the ones that i use the most.
Thank you
ios or android? In android you tap the 3 little dots on top right of device, here you can select rearrange, now drag the device up. IOS, bad luck
thank you!..
is there a way to change it in the web based ui? like chrome?
why in the web? you can add them to the favourites tab. open the fav tab, then drag them accross.
Not that Im aware of.
