climate and multisensor aeon
Not a Problem
Hi ,
I just installed the zipabox, for now I'm pretty disappointed in the interface and also the android interface. As it myself IT Architect, I am quite disappointed with the result.My first problem, I just installed the aeon of multisensor, I can not create a climate graph, an error appearsThermostat must have AT LEAST 1 Thermometer and AT LEAST 1 (Heating or Cooling) Actuator
im planning to buy the aeon multi sensor. So you are saying its not fully comp. with zipabox desipte its on zipatos homepage as covered?
Can you use all 4 sensors? Temp, motion, light and humidity?
I would expect 1 motion sensor and 3 meters on my dashboard.
Thanks! Makes sense with the thermostat.
I confirm the aoen multisensor is fully working! I am totally satisfied with mine.
First I think your Aeon sensor is not the problem.
To use Climate function I use the thermometer function of the Aeon sensor and then I use a Fibaro Power Plug as activator.
The power plug activator is connected to a 2000Watt electric heater of the bathroom.
Now
that i had this 2 modules add to the climate function, i can prepare
the week/day schedule/planning for the bathroom. I decide now that in
the morning the ideal temp from 7 to 8 o'clock is 24 °C. The climate
start the FibaroPowerPlug and send stop function at 8 o'clock or if 24°C
is reached.
Now
is reached.
