Climate - New GUI Temperature
DD shared this problem 11 years ago
in the new GUI its not possible to change the temperature easily - in the old ui i could use the cursor up/down to change the degrees in 0,1°c steps, now they are going in 1°c steps.
Using the mouse its not really possible to change the temperature its goind like this: 21 - 21,3 - 21,7 - 22 and so on.
Im using the old gui to change the climate in 0,1 steps (to get easily to 21,5, 22, 22,5 ...).
Best Regards
I would appreciate being able to just write the temperature. A slider, in my mind, is good for illustration but much less efficient for adjusting.
Yes impossible to change the temperature 0.1° I prefer write the temperature
3
I miss also from the old GUI the possibility to see directly if heating is on or off with a specific icon inside the climate widget. I also wonder if that is possible to remove the "cooling" information when only the heating is controled.
I think that is something important to consider. Perhaps get some inspiration from the way an air conditioning unit communicates what it's doing at the moment. It shows target temperature and whether it's heating, cooling, dehumidifying, ventilation etc.
I'm also not interested in the cooling part, so being able to disable the functionality one don't need would be nice.
And I'm a bit puzzled, you can add devices for humidity and ventilation - but how do you control this?
We have added this feature on our list of improvements. It may take some time until it becomes available.
