Climate with 0 degree
Pascal Wojciechowski shared this problem 13 years ago
Hello
My Climate widget indicates 0.0°Cjab9FiOPu0XX1HUlDd5j
I have a Thermostat Secure SRT321 that works welld7AYserT6I8kYxSHHLPH
And here after the parameters of this climate :
DE6pL45yCtaoSH3gRdS0
Help, please
BR
Pascal W
Replies (6)
OOOOUUUUAAAAAhhhhh
Thank you ! It Works... but what is the relationship between the alarm and the other widgets... This tips is not described in the online help!
This procedure solves the second issue i posted yesterday.
BR
Pascal W.
Thank you, but another problem:
Now, the value appears correctly in bottom left of mesure widget (Salle de bain temperature)
But in the associated climate widget (Salle de bain) that use the previous meter, there is no indication of temperature. So my climate widget doesn't work....ck4hnih5HaCL7U7u8Ey6
Thanks for your help
And Zipato on Iphone crach when i select the Climat widget....
Hello
And I have this error message when I click on one of button (Program, Permanent,...)
G6BOEe38uzgvPOBRcFMP
HELP
BR
Pascal W.
Dear Milan
It is very strange: I just open zipato dashboard to check and surprise: My Thermostat works well without action...
For information, the procedure you gave me is exactly the procedure i usually use.... So do you have update something on you server: a patch, a cleaning batch, a reboot.... ?
BR
Pascal W.
it's good for me too Milan.
