Danfoss and firmware 0,9,972
MilSabords shared this problem 12 years ago
Hi ! I just recieved my new Zipabox.
I made Update ... Include 13 new modules. Include / exclude ...
But impossible to include Danfoss living connect z ... I had Failed to insert ! But I can exclude it !??
What is the solution ?
Replies (6)
I don't own this device, but I heard that there are 2 versions:
one zwave compatible, and another wich isn't
You should check wich version you bought...
The version is 014G0012
I took a look on google, it seems to be the good one (zwave compatible)...
Are you sure to follow the good way to include it?
If so, maybe your danfoss module isn't working?
You should ask someone who uses this device how he did to include it.
Au fait...tu ne serais pas français par hasard? (au vu de ton pseudo) C'est fou le nombre d'utilisateurs français sur ce forum! ;)
Yes I m French, MilSabords ...
I find a way to success the including the 3 Danfoss.
I go to the rules part and back ... And now, with difficulty I have no error message after tring to include.
But now I have to find how it s work ... with rules ...
sous le couvercle sw 3.02 non compatible avec les box domotique
Ok great to hear you found a way to include it
I think you 1st have to use the climat widget to get it working.
