Danfoss still not compatible?
DK shared this question 13 years ago
Is it possible to create a rule to change the setpoint on a danfoss
(014G0002) when temperaturemeter (EZMotion) <= X degrees?
Been messing with all kinds of rules but nothing works.
Also getting errors when I use these two devices in climatewidget.
014G0002 is not compatible with Z-wave so it is not compabitble with Zipabox. You should use 014G00012
I got by misstake 2 of those and the strange thing is that my box could see those 2 014G0002 and add them to the network with the SET_TEMPERATURE as End Point butv I couldn't change it, sadly, so I will change to 014G0013 as 12 is not anymore.
You will to my knowledge still have to set up virtual thermostats to control the danfoss units and set SET_TEMPERATURE - both 0012 and 0013. Would have been interesteing to see if you could do it with the 0002 unit also.
With the one I bought before, a G0012 I think, I control it directly from the rules but when I tried with those it didn't work...
