Delete sensor from weather
Guest shared this idea 12 years ago
It's possible to delete a single sensor from the Weather sensor?
I'd like to have only the actual weather and not the forecast...
See attached picture..
thank you
Replies (9)
Added an option to hide Virtual weather endpoints.
Just go to Device manager, choose forecast endpoint you wish to hide and check Hidden field, then save. Refresh page to see changes in the widget.
It works for me.
In the same time, why do I have two times "Toulouse" in the weather stations?
thanks again for your very fast reactivity!
fredblabla wrote:
It works for me.
I guess there is two Toulouse in France. I will also add region there so it would make more sense.
It work fine!
Thank you very much
I do not think so, but I do not know everything. At least google map give me only one.
Go to add weather station now and search for Toulouse. I added region and there is two of them in different regions.
Thank youi, this improvement is usefull.
It is because the second toulouse (Franche-compté) has a real name: "toulouse-le-chateau"
Which database do you use? is it your own?
Database is from online weather service...
