how to delete a variable :)
delete variable
How to delete a created variable?
i have a same question...
http://community.zipato.com/responses/bug-or-feature-to-delete-a-variable
Trick: search for a rule by hitting space and then delete it... Vola you can see the variables... Right click and delete
you have a trick for know actual value of variable ?
and how can initiate a value of variable ?
holydays fo exemple, when i'am in holyday i can put value 1 to variable holidays
Not really But i guess you Could assign it to a virtual meter?
I normally create a simple rule, When sensor any then rule = 1...
Trick: put space in rule filter and then delete it. You see them and can right click to delete.
We will add separate tab for variables, but in the meantime you can pres 'X' on filter under 'My home rules', you will see Variables and Rules. Then you can delete variable with right click.
Thank you
Thank you
Hello. the new UI is already here, but the issue continues. Isn't it?
To delete a variable:
Voila..
Voila..
Hi all, I found this very good video:
https://www.youtube.com/watch?v=itLPzvEUF1I
Also, it is important to note that this problem does not occur if the AC codes are learned manually (regardless of the firmware version that is installed), but if the codes are selected from the schoolboy runaway drop-down list (from ZXT's code base), the problem is there, and the IR Extender is transmitting the three signals every ten seconds.
