EZ Motion 3in1 not added but detected when Zwave inclusion
Alberto Sagredo shared this problem 13 years ago
Im trying to join
http://www.expresscontrols.com/pdf/EZMotionOwnerManual.pdf
But not be able to do. I get a Join not successfull but device seems to be detected in inclusion mode when pressing inclusion button
Any way to resolve? is this sensor compatible?
Replies (18)
i try to add device but always "Join not successful", imediatly after press "join". No count down.
I can't remove device too.
It seems that it happens since one or two hours.
It seems like something is wrong with Z-wave module. Can you please unplug Zipabox from the power supply and plug it in again?
It worked
Now is included
After Unplug and plug power on ZIpabox, i can now join devices.
Thanks Sebastian, i 'm going to try if you've modify climate with ZXT120.
we prepared everything but still not publish the changes, maybe tonight...
Alberto Sagredo wrote:
It worked
Now is included
if it doesn't work, you should try again. Sometimes it goes to sleep during the joining process...
Yes, i see. But i can see progress too. Set point Heat, Set point Cool appear.
Good night.
I never had problems adding EZMotion 3in1 but I doubt compatibility.....
It does not work.
Tried several times, but no motion detecter, no info about temperature, no info about light
In devicemanager it shows up as HMS100.
Lighttreshold is not configurable :-(
Deleting, adding, re-apply, synchronize ==> 3 endpoints are there but only meters show up and no motionsensor.
Thanks Marko. Now Motion Sensor is on its place, but i do not see motion detection was working. Also no temperature or light reports on zipato.
Light on my EZ Motion detector is on/off slowly. Not as on my usual Zwave contraller were it was. Would leave for a minutes to see if its no motion tag you are commenting
Yes we are getting close but not 100%.
Cannot use the lightlevel
I get always NO MOTION on my.zipato.com. Also does not report temperature and light
Well , several tries later, i have my sensor and motion is detected
Temperature and light seems to continue do not work
Ok Now its showing temperature. Thanks
How much time does it refresh temperature from EZMotion? Once its motion triggered?
I do not see any option to configure that
Much better supported in version 0.9.91
I have seen that in 0.9.92 motion is show a sensor ON instead MOTIOn and Sensor off instead of NO_MOTION? Any reason to that?
