Failed to include duwi 05439 and duwi 05443
Renaud shared this problem 13 years ago
Any compatibility problem knows with this devices?
Thanks.
Replies (5)
Unfortunately, we currently don't support them. If they support standard Z-wave commandy, they should work anyway....
They support standard Z-wave...
Seems that each constructor have his own implementation of the standard.
No direct experience with this devices ?
In fact, all devices that i try to include fails. Why ?
The fibaro door sensor fail too.
It's a new zipabox setup. Maybee my zipabox have a problem.
How to check this ?
Same problem,
Zipabox find the module but fails to add
I have bougth now 3pcs of Z-way wall switches which are battery operated and only sticked to the wall with two sided tape. But Zipabox Duo does not recognize these.
When there will be support for these. I have tried to join them within 1m from Zipabox.
http://www.hans-hats.de/zwave-funk-wandsender-d%C3%BCwi-05443-p-4567.html?=
http://pepper1.net/zwavedb/uploads/resources/c47dc5e2d0b4e8bbdfd813398373b833c4db3f4a.pdf
Do I also need this in order to use battery operated Popp/ Duwi wall switches?
http://www.vesternet.com/downloads/dl/file/id/277/z_wave_duwi_repeater_with_controller_function_manual.pdf
