FGD-211 : S2 not working
Yann SALAUN shared this problem 13 years ago
My "Fibaro FGD211 - v1.9 - v1.10" S2 switch is not shown in "Light & Power" even after unchecking "hidden" in its parameter.
Moreover, when I push the S2 button I don't have any state return on my zipabox.
NB : S1 button work fine (but no state return like http://community.zipato.com/responses/cant-get-fibaro-fgs221-state-return)
Replies (5)
I also want to use the s2 on the dimmer but can't really get it to work :-(
would be nice if you could trigger a rule with it, but the only reaction I get with it is when I make a 'binding' - but that dosent really work either.
http://community.zipato.com/responses/how-to-use-fibaro-dimmer-second-switch
As far as i remember, S2 is inactive by default. One parameter has to be changed to make it active. (have a look in the Fibaro user manuel, it's written in a small note).
The problem is that i didn't find the way to active the parameter through the Zipabox interface, i did it with another bow.
If you want to install to push buttons, you don't need S2, but if you want to use the functions through the bow, then you need to active it.
No idea on this one Milan ? ;o)
Yann,
Hi zipato suport team,
Could we have an update on this issue ?
