FGK Door/Windows Sensor - Always Open (On)
ADN182 shared this problem 13 years ago
After i include my FGK (Fibaro) Sensor and simul open door my Sensor is always in Open state.
In the Event Section i have just one event OPEN and after nothing.
Same here! I have 4 FGK modules. All 4 where included correctly then worked correctly before mounting. After mounting, 2 are working perfectly and 2 shows the OPEN status even when closed.
I include my second FGK and i work when open and close but i have a 1 or 2 minutes after the status is apply. I remark the battery status don't appear with the fonctional FGK but with FGK " always open" (Alarm) the battery Status appear. I think the firmware version is different and cause this result
After sales service, change my FGK "always open" and now it's work the ILS was broken
This sensor still works this way.... You have had 3 years to fix this issue Zipato and still it is not fixed. Please fix the Zipabox firmware to deal with this problem. I have searched extensively and have only found problems with this sensor with Zipabox...the other controllers seem to be able to handle this sensor. Man up, zipato! :)
