FGS211 V2.1 issue
Help !, I can't disable the auto-off of this module !
I tried modifying all the parameters and auto-off is still activated :(
After looking at the documentation, to be able to stop auto off, auto-off time should be set at 0 but zipabox only allow range from 0.01 to 2.55.
Could you please fix that ?
yes +1.
yes +1.
Yes +1
same problem...
impossible to deactivate the AUTO OFF, kind of frustrating !
Yes +1
same problem...
Thanks for your answer.
Are you sure that the tested module has a v2.1 firmware ?
I already try that and it is not working at all ...
Done
Done
Hi!
Same for me, I tried to disable and it does not work correctly.
Hi!
Thanks to zipato support, it's working now for me (FGS 211 v2.1 is correctly recognized as such)
Great Job zipato team !!!
I have the same problem; I don't understand how you proceed to solve the issue.
best regardsn
Nicolas
best regardsn
Nicolas
Hi, please explain how you solve it because I can't on my side....!
Hi Frache and Sylvain,
I think you need to re-apply device descriptor for it to be correctly recognized.
