Fibaro dimmer broke?
I have a bi-stable switch and a Fibaro dimmer.
Since a few days my rule doesn't work anymore accordingly; only random "ghost-events".
If I move the slider on the dashboard the lightlevel does change, however in a few secs it jumps back to 40%.
Operating the wallswitch results in 100% or 40% light.
Is the dimmer broken?
Your dimmer is not broken.
We also noticed this problem and we are working on it. Soon it will be fixed.
We are sorry for any inconvenience this may have caused.
Tonight I had something similar:
- when I move the slider on dashboard to 0, the light turn off and few seconds later the slider go to 100% without turning on the light.
- when I move the slider on dashboard to ~80% (for example), the light is on at 80% and few seconds later the slider go to 100% without modifying the light.
- when I mode the slider to ~50% everything is ok.
Same for me the slider always go back to 0 whereas the light fortunately stays to the right value
Nenad Vojnovic Posted 5 days ago Your dimmer is not broken.
What do you mean with soon?
Problem solved with firmware 0.9.96
Thank you
Thank you
